Alright i have a 98 gsr that has been modified for a turbo kit but the
guy i bought it from did not replace the injectors like i thought he had. so it was running lean. anyways i put some double prong titanium spark plugs in. which i found out later was a terrible mistake (apparently you are only supposed to put coper plugs in a boosted car. anyways to make a long story short, the plugs i put in, literally exploded in the combustion chamber and took out an exhaust valve and left a ton of metal all over on the head so my question is... Where is a reputable place to send my head for machining, port and polish, and all that fun stuff? I am in Idaho falls and everyone i have talked to told me that i need to send it away cause no one here really knows anything about hondas/acuras. Good and low cost is definitely preferred. Also, should i replace my pistons? turns out they are stock not turbo pistons is that ok? and there is a bit of metal on them too from the spark plugs but i could probably clean em up if i keep them. any help you can give me would be awesome thanks Ty |
