-   -   Axle maybe? (https://www.acuraforums.com/forum/integra-22/axle-maybe-744/)
92integrals Dec 2, 2006 08:07 PM
Ok i got a 92 Integra LS here is my problem, when i make a right hand turn it makes a clicking noise it does not do it when i make a left hand turn.
Say it is the axle if i have the one changed should the other get changed as well, ive heard if one goes and gets fixed the other side is intended of going.
any help here at all would be appreciated thanks.....[img]smileys/smiley2.gif[/img]
integ89 Aug 19, 2007 11:47 PM
i have the same problem with my 91 integra i did a burn out turning left and the right side broke but i think im just gonna fix the one side cuz wat i think happened was the one tire was spining and the other wasnt so thats probably wat did it i have a clicking noise too im just as lost as u are i dont know how much they cost either
acuralegend Aug 23, 2007 08:02 AM
im betting on it being axle/axles
and there is no cost advantage to doing 2 at 1 time.
SOOOoooo. IMO only change the 1 that is bad.
P.S. CV axles are the strongest when perfectly straight.
the harder you are on then through a corner the sooner you will be replacing them.
