axle/hub question
Hey everybody my names Wes and I'm new to the acura scene, and i just had a couple of questions that you guys might be able to help me with. I recently purchased a 94 integra ls that got hit in the front end, so i got it pretty cheap. when it got hit, it was hit more or less right on the front driverside wheel, and it pulled the inner cv joint apart leaving the axle hanging, and bent the lower control arm. im in the process of pulling all this stuff apart so i can get to replacing things and my question for you is how to get the hub/spindle nut off with the axle broken. i havent yet attempted this but i would assume that if i just try to turn the nut the axle will spin with it because theres no resistance holding the axle still. is this correct? any help would be appreciated.
thanks,
Wes
