HELLO I HAVE A 96 INTEGRA 1.8 AUTO STOCK IM GETTING A MISS FIRE CODE CYLINDER 1 IM GETTING SPARK FUEL I ADJUSTED VALVE BUT COULD MY TIMING BELT OF JUMPED ?. IT RUNS AND DRIVES JUST STUMBLES AT IDLE... |
find out if the distributer will set timing correctly. if it WILL NOT then suspect a jumped belt.
im betting on a sticky injector or possiably a burnt valve. have a cylinder leak down test performed to see if that valve set is ok. |
OK GREAT THANKS FOR UR HELP |
i think you must change the timing belt. have you already check the engine filter? G luck[img]smileys/smiley10.gif[/img]
someday man someday i'll buy that car too [img]smileys/smiley8.gif[/img] |
ya i gotta check that too..
| All times are GMT -5. The time now is 09:14 AM. |
