HI, I recently runined my front driver side bearing by hitting a bump on a dirt road... and had it replaced..
since then My integra eats rotors on that same wheel! I replace 3 in the last 8 weeks! and i also replaced the calipar and rotor yesterday and it did not help at all! when i hit the brakes my steering wheel starts viberating bad and the the whole front end viberates bad and I feel like I can't stop! I know that my rotor up there is badly warped again and I desperately need to fix my brakes and for cheap from the nearby salvage u pull yards, because i drive 1,000 miles a week. anyone know what I need to do? thanks much! |
sounds like you replaced a bearing. but reinstalled a bent hub.
got a dial indicator? im betting you have more damage than you thought. |
| All times are GMT -5. The time now is 06:49 AM. |
