-   -   95 LS with squeeky radiator fan/motor (https://www.acuraforums.com/forum/integra-22/95-ls-squeeky-radiator-fan-motor-350/)
cbswan Mar 26, 2006 11:48 PM
Last fall my radiator fan/motor began squeeking very loud whenever it kicked on, either when the engine got hot or I ran the A/C. My quick fix was to remove the fuse so the fan motorwould not run. Now that the warmer temperatures are returning, I will need the fan to keep things cool. I am not sure it is the fan or the motor. I don't think it is a belt because I do not see any belts associated with the fan and motor. Please correct me if I am wrong. I am seeking some guidance in correctly pinpointing the problem and advice on how to best fix it. Please help. Thanks.
SFlynn88 Mar 29, 2006 06:02 PM
either replace or rebuild the motor, it's definatly the motor.
cbswan Mar 29, 2006 10:55 PM
Does anyone know if this is difficult to replace. I can do many repairs, but I don'tknow if this requires special tools or knowledge.
SFlynn88 Mar 30, 2006 12:01 AM
not that hard, just get a hanes manual and you'll be set.
