-   -   won:t start (https://www.acuraforums.com/forum/general-tech-14/wn-t-start-1698/)
tomcat Oct 23, 2007 05:46 PM
just replaced ignion asembly key wouldn"t work on old oneon 2000 interga ,turns over but won't start. i realy need help i/m bown to one car between wife and son i'm in the middle ant just spent 300>00 on ing asembly thanks
acuralegend Oct 28, 2007 02:48 PM
9 OUT OF 10 TIMES a no spark crank no start issue is the distrubiter
during the summer it can be a main buss relay.
a new dist will run you a couple hundred
a new main buss will cost under 100
having a tech look it over before waisting gobs of cash on stuff you dont need...priceless.
acuralegend Oct 28, 2007 02:51 PM
now if it was running right befor you changed your switch and now its dead after you finished your install recheck your bolt in fuses 40-80amp.
spacifically your ECM fuse.
tomcat Nov 2, 2007 07:49 PM
thanks for the info the problem was the imobilizer-the new key needed to be coded to the car's computer. duh
