[img]smileys/smiley19.gif[/img]My 1998 acura cl srb light came on. Now it won't start. Has power, just clicks when you try to start |
< => <!-- var SymRealOnLoad; var SymReal; Sym() { window.open = SymWinOpen; if(SymReal != null) SymReal(); } SymOnLoad() { if(SymRealOnLoad != null) SymRealOnLoad(); window.open = SymRealWinOpen; SymReal = window.; window. = Sym; } SymRealOnLoad = window.onload; window.onload = SymOnLoad; //--> </> just a few suggestions in case you havent started your car yet. 1. check yhe batery and try to jumo start it. 2. once it is started disconect your battery, if it dies you need a new alternator 3. check your connedctions to your battery and alternator to make sure they are clean and free of debries also check your fuses. good luck!! |
have you checked to see if the connections on the started are tight and the ground is connected Josh |
