VSA Light 2004 TL
Every so often my VSA light comes on along with the triangle VSA hazard light. If I turn the car off and on again it disappears and the car drives fine. If I turn the VSA off is this something that I should continually do?
Hi Member
Are you sure that light isn't a VSS light..Vehicle Speed Sensor?
that's the traction control lite.........you need to clear the code, to do so you need a scanner.. if once cleared it comes on again take it to dealer or a shop that specializes on acura to diagnose it,,
Hi Member
1 Attachment(s)
Did you ever get that problem ironed out on your car?:)
(Post 9767)
yeah its right Bump. +1. is the code most likely for the VSS.There are various tools needed to clear that code in this website.
What is VSA
Sorry guys i am new and trying to find things out about my car 2004 Tl and also does the homelink thing really work i have been trying for a week now..
| All times are GMT -5. The time now is 05:48 AM. |
