-   -   transmission problem or not (https://www.acuraforums.com/forum/general-tech-14/transmissin-problem-not-765/)
lizzard08 Dec 8, 2006 11:51 PM
1995 Acura Integra ls, Coming home from school and the car started pulling to the left real hard and vibrating bad. Then it acted as if the clutch went out, it wouldnt go no more. Found the left axel cv joint bad. When the transmission is in gear the front wheels turn freely as if its in netural. I pulled the Transmission and the clutch does'nt look that bad. The transmission shifts ok and rotates as normal. Can anyone help figuring out this problem I've got a new clutch set up but wonder if thats what the problem is. With the car on stands and rotating the front wheels by hand with the car in gear should'nt there be resistance from the motor well there not. HELP
Kase28533 Jul 29, 2007 05:31 PM
If your car is off and still in gear it acts as a brake. Yor tires should not move at all. Check your transmission fluid, If it is brown and/or smells burnt, that is a good indication that you need to repair your transmission.
