RSX Headlight Problem
Old Aug 28, 2007 | 05:52 AM
TBooz13's Avatar
Hey All -
I have a 2003 RSX and the driver side headlight went out. I put in a new bulb twice and neither one worked (and no, I did not touch the glass part of the bulb). I then proceeded to check the fuse and changed it for good measure, and that didnt give me any light either. Any ideas what my problem might be or how I fix it?
Old Sep 10, 2007 | 09:02 PM
acuratech's Avatar
You needvolt meter to test for voltage and proper ground. Other than that....There will be more thanone fuse for the lights as well. Check both fuse boxes. That bulb is really hard to get at, You may want to take the battery out as it is in the way. This will alow you to see if you have it plugged the bulb in propery (no shame in that right). Did the first bulb look burnt?
Edited by: acuratech
Old Sep 13, 2007 | 08:12 AM
look for bent pins or blackened plastic in the bulb plug.
after that it's test light/volt meter time
Old Nov 29, 2007 | 01:09 PM
carjoe55's Avatar
there is a great website that I found that has good deals on headlights if yours are broken I have a link check it out and let me know what you think of it? http://www.yourhotcar.com/parts/Head...p;_Tail_Lights
bbsitum
Dec 20, 2008 01:09 AM
DOZOIR
Sep 5, 2008 04:02 PM
DOZOIR
Jul 31, 2008 08:57 PM
weavafeva18
Nov 27, 2006 11:40 AM
rsxdude
Oct 24, 2005 04:36 PM
