Headlight bulb went out on my 2000 acura rl 3.5 and the replacement bulb cost $120.00. Once Iinstalled the new bulb*(light will not come on)nothing happened. Whatmight I be doing wrong? any help would be appreciated!
Did you replace the whole headlight assembly for that kind of money?
WheelBrokerAng [img]smileys/smiley16.gif[/img] |
As I stated in your other post of the exact same thing.... Your bulb may have not been bad in the first place. Your inverter or ignitor is probably bad. Those are significantly more expensive. And much more expensive if you plan a just guessing at it. Your not gonna want to hear it... but you should take it to the dealer and have them test your components. on a side note... did you check your fuses? ps... no wheelbrokerang... that is the price of the HID bulb. Edited by: Greenbling |
Thanks for clearing that up..I thought that it was, but was not sure [img]smileys/smiley2.gif[/img]
WheelB rokerAng [img]smileys/smiley16.gif[/img] |
| All times are GMT -5. The time now is 03:52 AM. |
