-   -   Need Help with ’89 Legend (https://www.acuraforums.com/forum/general-tech-14/need-help-89-legend-128/)
chef5280 Jul 14, 2005 02:11 AM
I have a problem with the car not starting when the
weather is hot. The starter will crank but it just won't
turn over. when it cools down at night/morning, it's
just fine.
I've heard theories ranging from the control module
in the distributor to the fuel filter.
At 266,000 miles, I can't complain.Any expertise
you folks can provide is greatly appreciated.
Thanks
WheelBrokerAng Jul 14, 2005 03:28 AM
var SymRealOnLoad;
var SymReal;
Sym()
window.open = SymWinOpen;
if(SymReal != null)
SymReal();
SymOnLoad()
if(SymRealOnLoad != null)
SymRealOnLoad();
window.open = SymRealWinOpen;
SymReal = window.;
window. = Sym;
window.onload = SymOnLoad;
//--></>Hi...
Here are a few reasons why cars will not start when Hot...
Air filter clogged....Fuel not reaching the the fuel injector system (fuel pressure checker) to analyze this, and believe this or not...coroded battery cable connections, especially the ground cable...
Check this out and let me know...WheelBrokerAng
var SymRealOnLoad;
var SymReal;
Sym()
if(SymReal != null)
SymReal();
SymOnLoad()
SymRealOnLoad();
SymReal = window.;
window. = Sym;
</>Edited by: WheelBrokerAng
chef5280 Jul 28, 2005 01:48 AM
Today, I tried changing out the air filter, which was
(necessary anyway) It started right up once. Then I
tried to start it again. Out of 6 or 7 times, it started
twice, then no more.I got a faint whiff of fuel. It just
cranks, but won't turn over.
Possibly a fuel system issue?
Clogged fuel filter?
Not enough initial pressure on startup?
Any other ideas?
Again, thanks for any assistance.
