AKinDen |
01-22-2007 10:16 PM |
Ok, this is a tough question. Sinceno one has answered it yeti'll give it a shot.Here's part of the list...  ;  ;  ;  ; - A GS or LS manual tranny prob 94-2001 W/ manual trans mounts
- Flywheel, clutch, clutch master cylinder, slave cylinder, clutch hydraulic lines, Starter, manual pedal assembly, shift linkage, shifter W/knob, shift boot, ECU from a gs/ls with manual, a throttle body from a manual, intake manafold from a manual and some rewiring on your harness. Also your gagecluster won't match.
This swap is major surgery, expensive and time consuming. https://www.acuraforums.com/smileys/smiley6.gifIt wouldcost you lessto sell the car and getaGSthat comes w/ a manal trans. I have a manual GS andI love it. Best of luck with whatever route you take.
