How About a Question and Answer Question!
Old Oct 7, 2004 | 04:02 AM
I am going to start a little question and answer section in here for the members who would like to learn things about their rides.
These questions will not be meant to make anyone feel dumb, but will be put in here to Help You better understand things about your ride when it "All Goes Bad "....
1st question...and please respond if you'd really like to know if your right...or if your not right...
Thanks for the space...
Question#1
You go to start your ride and you hear your starter motor which sounds bad (noisy) and when it starts your car is excessively rough in engagement. (HINT) There are TWO main reasons for this common problem. Take a wack at them with your best answers..
Have fun...WheelBrokerAng[img]smileys/smiley16.gif[/img]
[img]uploads/WheelBrokerAng/3ZFZ8_BonSpeedLaguna2pcSmall.jpg[/img]
Old Oct 12, 2004 | 11:38 PM
josh's Avatar
I have a QUESTION? Will a 91 Acura Legend3.2 V6 swap to a 94 Legend V6?
Old Nov 1, 2004 | 11:50 PM
Now thats a great Question..
If the motor mounts and the transmission mounts match up then you are half way home, check with advance adapters in Cleveland, Ohio and they will give you that best answer you want...
Next thing is to call Your Acura people at the local dealership and see if the two cars computers are compatable...
Hope this Helps you a little bit...
var SymRealOnLoad;
var SymReal;
Sym()
window.open = SymWinOpen;
if(SymReal != null)
SymReal();
SymOnLoad()
if(SymRealOnLoad != null)
SymRealOnLoad();
window.open = SymRealWinOpen;
SymReal = window.;
window. = Sym;
window.onload = SymOnLoad;
Old Dec 23, 2004 | 02:57 PM
ts.shooter's Avatar
I have a question i,ve a 88 acura legend that,s starts and runs well i can go anywhere in it but when i stop say for gas i have a hard time starting it any thoughts[img]smileys/smiley1.gif[/img]
Old Jan 31, 2005 | 02:46 AM
var SymRealOnLoad;
var SymReal;
Sym()
if(SymReal != null)
SymReal();
SymOnLoad()
SymRealOnLoad();
SymReal = window.;
window. = Sym;
Maybe your fuel pump does not have the fuel pressure that it needs to keep the fuel flowing at all times.
If you have a friend that has a fuel pressure checker, have him run it for you to check that pressure, by the way! have you chaged your filter in the last 15,000 miles? If not your past due now...
liberty2599
Oct 31, 2012 08:30 AM
shaky1977
Apr 8, 2008 09:05 PM
dj2xrated
Oct 11, 2007 08:27 AM
