-   -   FUEL INJECTION PROB (https://www.acuraforums.com/forum/general-tech-14/fuel-injectin-prob-382/)
ARRIZON8 Apr 24, 2006 05:34 AM
I RECENTLY STARTED TO HAVE PROBLEMS WITH MY CAR NOT STARTING AT TIMES, I KNOW IT WILL THE FUEL INJECTION, BUT I DONT KNOW WHAT IT IS, MY FUEL PUMP IS FINE IT ALMOST KNEW, BUT I DID NOTICE THAT WHEN IT IS HOT OUT IT IS HARDER FOR MY CAR TO START. I TURNOVER THE KEY AND THE PUMP DOES NOT START TO PASS FUEL, I JUST CHANGED THE FUEL INJECTORS AND THAT STILL DOES NOT HELP.!!!! WHAT SHOULD I DO!!!!!!!!!!!!
Patrick Apr 27, 2006 01:06 PM
i have heard of this problem with a few different makes of vehicles, and it was typically either a fuel pump issue (which you think it is not), an ECU problem, or a crank sensor issue...any past issues with those?
feel the heat Aug 19, 2006 02:43 AM
It is the main fuel relay. I had the exact same problem, I changed my main fuel relay and have not had a problem since. It costs about $70 for the part.
acuralegend Sep 17, 2006 03:49 PM
Look for a corroded or faulty fuel pump relay/fuse.
