-   -   engine problems. (https://www.acuraforums.com/forum/general-tech-14/engine-problems-546/)
teggy Aug 29, 2006 12:36 AM
when i start the motor it revs to 5000 rpm.
the engine hasent been sarted in 10 months until today
i put a fuel rail on the car and chipped it whith headers
but i remouved the chip thinking that was the problem
acuralegend Sep 17, 2006 03:30 PM
A 5k start up rpm...yike...
I would look into a:
stuck open idle control circuit.
Stuck throttle cable.
Unplugged wires
Huge vacume leaks.
Corrosion on ground wires my give false voltage to sensors and trick the computer.
Also check if the engine has codes or a service engine soon light.
but try not to start it if that 5k is still happening...oil pressure
isnt there yet and with out it you can have serious engine damage.
I wouldnt look into the fuel system...it runs
I wouldnt look into the ignition...it runs
