Cooler temp after intake install?
What's up guys...I noticed my RSX's temp gauge is registering a bit
lower than usual after I installed the aftermarket intake. Would I have to disconnect the battery to reset the ECU, or should the ECU automatically adjust the air/fuel mixture? |
Let's see if some one knows this answer and comes in and tells you!
Good Luck:) |
