changing fuses in acura cl 98
Old Aug 5, 2004 | 04:02 PM
argetineangel's Avatar
i lost my manual, and my radio fuse is blown please help me!!!i want to change it but dont know the specific fuse is.
Old Oct 7, 2004 | 03:28 AM
Hi:
When you go to change that fuse make sure you use some caution such as this...If the radio in your Accura is equipped with an anti-theft system, make sure you have the correct activation code before you try disconrcting your battery or you may be towing your ride to your local dealer to get your car up and running again..
Later..WheelBrokerAng[img]smileys/smiley16.gif[/img]
[img]uploads/WheelBrokerAng/D6469_wtfdance.gif[/img]
Old Feb 8, 2005 | 04:07 PM
Bconn210's Avatar
Well I am not sure the fuse number but its is under hood fuse box and all I would do is just start pulling your fuses out and looking at them or test all of them with a test light and find the bad one and replace it. If you decide to pull them out one at a time look at metal in the fucse if it dose not connect theres you problem. GOOD LUCK!
acekaroo
Mar 27, 2008 07:55 PM
Bhummel
Jan 3, 2008 05:59 PM
argetineangel
Nov 12, 2007 11:10 PM
mpret4888
Jan 16, 2007 01:50 AM
argetineangel
Aug 31, 2004 06:50 PM
