-   -   ANY IDEA WHY....... (https://www.acuraforums.com/forum/general-tech-14/any-idea-why-61/)
Bigboi Mar 10, 2005 09:01 PM
var SymRealOnLoad;
var SymReal;
Sym()
window.open = SymWinOpen;
if(SymReal != null)
SymReal();
SymOnLoad()
if(SymRealOnLoad != null)
SymRealOnLoad();
window.open = SymRealWinOpen;
SymReal = window.;
window. = Sym;
window.onload = SymOnLoad;
I'm new to this thing. I own a 95 gsr and the motor is leaking on the side of the distributor (leaking oil)....any idea of what i can do, or anybody knows the problem, let me know.....Thanks
SMYLIE Apr 26, 2005 01:33 PM
var SymRealOnLoad;
var SymReal;
Sym()
if(SymReal != null)
SymReal();
SymOnLoad()
SymRealOnLoad();
SymReal = window.;
window. = Sym;
[img]smileys/smiley17.gif[/img] go to a carwash , clean off the oily side,and get a closer look. can you zero in on where its coming from? use a mirror and flashlight, whatever ,first "find" the source...
Bconn210 Jun 8, 2005 05:04 PM
If it is comming from behind the distributor it is the distributor O-Ring It also could be comming from the cam plug which is the plug in front of the distributor behind your V-tech Solenoidtowards the front of the car. They are both very common to leak on that mode. GOOD LUCK!!!
