| DAHLHOUSE |
Dec 3, 2025 02:08 PM |
Acura Integra windows
Anyone else have 2025 Acura Integra Window issues? Specifically, at high speeds if you roll the window down, then back up, it won't close all the way. Air gap left. Only by getting to a low speed (35 mph or less) will you be able to close correctly. Took it to the dealer. Dealer saw the issue, then test drove other integra's and said it was clearly a factory defect but did absolutely no work on it as if Acura doesn't see it's a problem or not noted in here on the forum, the warranty won't cover their work unless it's a known issue. So, Acura, please fix defect. Sincerely, an irritated customer.
