acura cl3.0 1998
Newly aquired 1998 cl 3.0 it just stops running ..without warning...
can someone give a clue as to why it does this
Hello New Member
1 Attachment(s)
There can be many reasons as to why, but these are 3 of the most common reasons:
#1 Loose connections at, distb, ign coil or alternator #2 Not enoughf fuel reaching the fuel injectors #3 Vacume leaks in the lines or even the gasket between the intake manifold or the throttle body... Good Hunting...WheelBrokerAng clik the pic |
Usaully it is some type of fuel pick up problem, or fuel filter. It is possible the engine was slightly flooded, causing it to loose power.
I think there must be some problem in engine.Or its better you should go and meet the car mechanic,he will definitely make it solve.
| All times are GMT -5. The time now is 02:37 AM. |
