-   -   '97 Acura CL 3.0 engine revving in P/N (https://www.acuraforums.com/forum/general-tech-14/97-acura-cl-3-0-engine-revving-p-n-4053/)
synistar04 01-15-2010 03:54 AM
Hello all. I'm driving a 1997 Acura CL 3.0. Some time ago, out of the blue mind you, the engine would rev up while I was in park or neutral. It would only occur once the car had warmed up for a few minutes and did fine when in gear, and holding the brake down. At first, it began revving up to about 3000 RPMs but I replaced the idle control which brought it down to about a 1500 RPM rev.
Is there anything else I could check or fix to rid myself of the rev?
Thanks.
WheelBrokerAng 01-16-2010 04:25 PM
Hey another new member
How come you newbies don't ever announce yourself's in the new member area...?:)
WheelBrokerAng 01-16-2010 04:32 PM
Check These Things...
1 Attachment(s)
Thanks.
:) You may have a faulti Throttle Position Sensor or a Fuel Pressure Regulator that is not working properly...
synistar04 01-17-2010 10:16 AM
Hehe sorry I was in a hurry when I posted so I just threw it out there really quick. :P
But thanks a ton for the reply man, I'll have to have those two things checked out and hopefully get down to the problem.
