1990 legend 2dr 2.7 LS First time post, Now I've just turn 100,400 mi on it and things seem to be needing some tlc. the bose system bit the dust and pioneer had to take it's place. some questions i have ?1. egr valve or o2 scensor [check engine light (code seems to blink non-stop)] front o2 covered with oil from valve cover gasket leak/ soon to be changed/ small leak but time has covered the sensor. ?2. intermitant a/c, runs fine than stops than runs fine after undetermined and speratic amount of time has passesd. ?3. abs light (puled three fuses to run regulal braking) prior to light there was a slight knockining sound under driver side hood. is there a way to isolate problem to a scensor or relay before big $ high presure pump replacment? ?4. engine temp high at times (turnimg heater on down here in florida not fun), i've replaced temp scensor at bottom of radiator, anything else i might change check? help is in need, thanks eric Edited by: spud121 |
On itemfour, change the thermostat and make sure you have 50/50 coolent in the system. Make sure the fans come on when it is hot. Use factory parts. No, I have no stock in Honda and do not own a dealer or even work for Honda or Acura. Their parts just work better. I know this from experiance. On all the other items, get the factory service manuals and study them. They won't be cheep! https://www.acuraforums.com/smileys/smiley16.gif |
