2003 acura el 1.7
I have a freinds car that broke the T/belt,bent the valves and did the head and valves,water pump,gaskets,oil change and filter,all the needed stuff to get it back to running order.Problems now,its got 250,000KM on it,and has codes :P1259,P0505,P1505.Oil comsuption is high after the R&R the cylinder and seals,just want to solve the code problems and see if gains back its power loss.The Timing belt is right on,and want toget a good picture of the dampener for the marks,as the dampener has two small lines for timing and TDC,if you use the rod in the spark plug hole method its dead on.If you can help,great,email me back or give me a quick call and your number to call you back on my dime,mrmopartech penstarperformance@videotron.ca 450 424 0445/514 659 0445 This is a VTEC motor,canadian car? |
