2000 Acura rear view mirrow
Well first make sure the auto switch is on. If all is on you can test the mirror connector just remove the map light console and there will be a blue 2 pin connector test for power there and if there is power the mirror is bad. I have seen lots of those go bad Rec. replacing mirror. GOOD LUCK!!
