yea, i have constant condensation in my left headlight, any ideas on how to fix that? 96 acura rl
replace the rubber seal between the bulb and headlight housing.
also make sure there is no pin hole due to rock inpacts in the front lenz also make sure the rubber bulb cover is on. if the light has side marker bulbs in it as well double check those seals as well. drain all the old water out befor sealing this up tight. |
that did the trick, thanks
| All times are GMT -5. The time now is 10:34 AM. |
