-   Engine & Internal (https://www.acuraforums.com/forum/engine-internal-28/)
-   -   Spark plug replacements? (https://www.acuraforums.com/forum/engine-internal-28/spark-plug-replacements-519/)
integraid95tg Aug 7, 2006 08:42 PM
What is a really good company to buy high performance spark plugs from for my 95' integra?
all recommendations are appreciated,
thanks[img]smileys/smiley2.gif[/img]
integraid95tg Aug 7, 2006 08:46 PM
oh, and what temperature of spark plugs do I need to get?
acuralegend Sep 18, 2006 11:37 AM
NGK OEM spec
if you have a turbo or other means of forced induction the drop the heat 1 stage.
if you have a oil burner the bump the heat up 1 vs the stock range.
The problem i have had with the platnums or the 4electrode or the
splitfires or whatever is NASCAR/NHRA/SCCA racers dont run them...Hmmm
if there that great why doesnt the great ones use them???
Also the short lived 10k-maybe 30k if your lucky. Those NGK plugs should last you 60k-100k.
Im only a ASE Master teck with 23 years exp in the field.
