-   Engine & Internal (https://www.acuraforums.com/forum/engine-internal-28/)
-   -   JDM engine swap.. (https://www.acuraforums.com/forum/engine-internal-28/jdm-engine-swap-1501/)
1.6el Sep 3, 2007 08:54 PM
so i have a 2000 1.6el and as the subject says, i'd like to throw a jdm engine in it. as most know, el is pretty much a civic so im curious if anyone would know if it's possible to put a jdm honda engine in, and if it uses the same mounts, etc. and if so, if anyone knows which would be the best to put in.
thanks for the help
acuralegend Sep 15, 2007 07:54 PM
so far i have not run into any JDM install issues If you reuse your
harness, sensors, manifolds, pan, and oil pick up tube. but it
has to be a matching year engine.
