< src="http://www.google-analytics.com/urchin.js" =text/> </>I just bought a 1987 Acura Integra RS yesterday. It sat for roughly 10 months I know everything needs pretty much worn back in: brakes fluids and stuff but the clutch is slipping pretty bad I'm not sure what type of clutchit has but what do you think the problem is... Rust on a dry clutch plate? It is not slipping as much by the time I got it home but still pretty bad. Do you think it will wear back in or just straight up need replaced? < =text/> _uacct = "UA-939292-41"; urchinTracker(); </>< src="http://www.google-analytics.com/urchin.js" =text/> </>< =text/> _uacct = "UA-939292-41"; urchinTracker(); </>
< src="http://www.google-analytics.com/urchin.js" =text/> </> < =text/> _uacct = "UA-939292-41"; urchinTracker(); </>Edited by: Toyo_drifting |
I guess you need to replace your clutch. Try to visit automotive shop so they can check the problem of your clutch. If you need replacement just browse auto shop store online they have wide choices such as</span> Acura CL clutch kit.< src="http://www.google-analytics.com/urchin.js" ="text/"></>< ="text/">_uacct = "UA-939292-41";
urchinTracker(); </> |
Clutch Slipping is a condition that occurs when the armature plate fails to engage and rotate in synchronization
with the clutch rotor. What i did was to replace the <a href="http://www.car-stuff.com/mmparts/acura-vigor/clutch_kit.html" target="_blank">acura vigor clutch kit</a></font></span>< ="text/">cct = "UA-939292-41"; urchinTracker(); </> |
