1 idea that can work if done right is to have your springs cut.
stock springs can handle 1-2 inches cut from them in most cases.
as long as there not cut so short that they can fall out of there perches at the fully extended position.
cutting stock springs will also increase you spring rate a little. this will also cause a stiffer ride.
resulting in better handling.
plan on a alighnment when its all said and done.
P.S. springs cut wrong or just detempered can kill (HAVE A PRO DO IT PLZ)
