< => <!-- var SymRealOnLoad; var SymReal; Sym() { window.open = SymWinOpen; if(SymReal != null) SymReal(); } SymOnLoad() { if(SymRealOnLoad != null) SymRealOnLoad(); window.open = SymRealWinOpen; SymReal = window.; window. = Sym; } SymRealOnLoad = window.onload; window.onload = SymOnLoad; //--> </> My 97 Cl 2.2 is equipped with the acura security protection. Sometimes it chirps and sometimes it doesnt. My mother also has a 97 acura cl 3.0 but her's I can program to chirp and not too chirp. How do I program this one or is there just something that needs to be fixed? Thanx much |
I have had this occur several times with my '97 CL 3.0 and have always been able to resolve it by reprogramming the remote keyfob. From your post, you sound like you have done the reprogramming of the fob before, but from the the number of views on this topic, I am posting the steps for reprogramming the keyless entry system just in case anyone is searching the forum for these steps. ***********Disclaimer******************* I have tested this only on my own 1997 3.0 CL ************************************* <DIV>1. Turn the ignition switch on (II on the ignition) 2. W/in 1-4sec, push the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit. (Just at the steering wheel is fine) 3. W/in 1-4sec, turn the ignition switch off 4. W/in 1-4sec, turn the ignition switch on(II) 5. W/in 1-4, push the transmitter lock or unlock button w/ the transmitter aimed at the receiver again. 6. W/in 1-4sec, turn the ign. switch off 7. W/in 4sec, turn the ignition switch On(II) 8. w/in 1-4sec, push the transmitter lock or unlock again. 9. w/in 4 sec, turn the ign off 10. w/in 4 sec, turn the ign ON 11. W/in 1-4, push the transmitter again 12. Confirm you can hear the sound of the door actuators. W/in 1-4sec, push the trans lock or unlock button again. 13. W/in 10sec, aim the transmitters (up to three) whose codes you want to store at the receiver, and press the transmitter lock or unlock buttons. Confirm that you can hear the sound of the door lock actuators after each transmitter code is stored. 14. Turn the ignition switch off, and pull out the key. 15. Confirm proper operation with the new codes </DIV>Edited by: thorzstone |
Thorz thank you that info is awsome.
| All times are GMT -5. The time now is 06:46 AM. |
