< src="http://www.google-analytics.com/urchin.js" =text/> </> I need some help please. My 98 2.3CL. Yesterday morning i turned on my car to warm it up. Turns on fine. While scrapping the snow off of the car all of the sudden my car turns off on me. I try starting the car right away. Nothing. No crank. No click. And my battery seems fine. None of my lights are dim what so ever. Ten minutes later I try starting my car and it starts without a problem. I give it a little gas and after I let go the car turned off again. As of then it hasn't turned on. Does anyone know wat this could be? < =text/> _uacct = "UA-939292-41"; urchinTracker(); </> |
it sounds to me like the alarm system is kicking in and shutting you down. thinking its being stolen or something.
a module running that may have gone flakie. could your charging system be overcharging and as a safty precaution its shutting off the car? corrosion in the fuse box can cause so weird stuff as well. is some one playing a prank on you and hitting the remote from inside the house? < src="http://www.google-analytics.com/urchin.js" ="text/"></>< ="text/">_uacct = "UA-939292-41"; urchinTracker(); </> |
i have an aftermarket security system by clifford. its never givin me trouble. i was reading about a recall on the ignition switch and was thinking that was the problem < src="http://www.google-analytics.com/urchin.js" =text/> </> < =text/> _uacct = "UA-939292-41"; urchinTracker(); </> |
yes hondas/acuras do have a history of bad ignition switches.
and if you have a ton of keys on your ring it can reak havoc to them. but i just ripped out a clifford alarm system from a 92 tegra today because it was doing almost the same thing. if it allowed the car to start it would shut down after a few min. this system disabled the fuel and starter and ignition. sounds like its time to get a tow to a repitable shop and have them check it out. with what you told me on how it runs and dies then wont do a thing. i would suspect a aftermarket alarm first befor all other. < src="http://www.google-analytics.com/urchin.js" ="text/"></>< ="text/">_uacct = "UA-939292-41"; urchinTracker(); </> |
it only did that once. and it doesn't start anymore. i dun think it would be the alarm system. i have never have had any problems with it at all < src="http://www.google-analytics.com/urchin.js" =text/> </> < =text/> _uacct = "UA-939292-41"; urchinTracker(); </> |
I had an identical problem to a vehicle I once had. It ended up being a cracked relay that intermittently caused the car to die/not start. I got the cracked relay repaired (as I was on vacation and couldn't afford the time it took to order a new one) and it was great for the next 5 years till I sold it. The extreme cold weather may have done it to you, just an idea.
