1998 2.3 CL - I have a leak up under my glove box. It occurs when I run my defroster and/or heater for any length of time. Condensation and waterare bothapparent on the air vent tubingit travels through under my dash board.It does this periodically not consistantly unless excessive use of air/defroster is ran. What's strange is when I turn my wheel (while driving) to the left the water is excessive with what sounds like a forced pressure sound. It will mildly pour down my front floor board and eventually stop. If the heater/defroster continues to run it will drip occationally. When I make that left turn is when it sounds like it releases itself. WHAT IS IT? It's driving me cwazy! I've torn out my glove box, and split apart the seam to the vent....nothing. Ipulled upthat seal that obstructs things from getting into the outside vents - under my hood/bottom of the front window, ANDthe insideof the window's seal...NOTHING. HELP...? Any one heard of or maybe experienced... such symptoms? |
i have the same problem .. i think it might be that it needs free-on.
