-   -   CL 1998 - List of Recommended Repairs from Mech, 140K miles (https://www.acuraforums.com/forum/cl-21/cl-1998-list-recommended-repairs-mech-140k-miles-8659/)
RjMil1 Jun 17, 2025 05:22 PM
Hi, believe I need to consult CL 1998 experts. It's been a great car. Currently doing exhaust per prior Acura Service Center recommendation (eg "Must Do") and received a list of additional recommendations. Would appreciate if anyone has sense of how to order these. Will need to determine correct mechanic (general mechanic has been a mistake for me, should have gone with Acura and Honda specialists or specific service specialists and trying to learn from this!). Service Center said for some issues eg exhaust they asked I have it done at a different location because they couldn't get parts. Will likely get a second multi point inspection as well (though not at the service center). Your wisdom greatly appreciated.
NOTE | NOTICED OIL LEAKS AT REAR ENGINE SEAL.
Other Recommendationa
REC. REPLACING A/C COMPRESSOR COMPLETE ASSEMBLY, CONDENSER ASSEMBLY, RECEIVER DRYER, TWO SMALL SCHRADER VALVE CORES
[Believe postponing as of now]
OTHER | REC. REPLACING CRANKSHAFT PULLEY AND DRIVE BELTS. CRANKSHAFT RUBBER DAMPER IS CRACKED PULLEY WOBBLE/ NOISY AT IDLE. NOTE 12
OTHER | REC. REPLACING POWER STEERING GEAR BOX COMPLETE ASSEMBLY WITH INNER AND OUTER TIE RODS. P/S RACK IS LEAKING.
Thanks for considering! June 2025.
