hey guys i have a problem last time i was driving my clutch wouldnt let me put the car in any gear an when i finally got it in the cr wont run anymore i would think its the tranny but when i put the car in gear you can hear the shift but the car wont move but it will start an catch gears plz someone help me
look under your dash under the steering column look for the clutch pedal linkage going into the firewall.
I be you will see black goop drippin off the linkage or running down the firewall and into the carpet. honda/acura's eat clutch master cylinders. double check the clutch fluid resivore make sure its full of fluid. |
