-   Audio/Visual Electronics (https://www.acuraforums.com/forum/audio-visual-electronics-25/)
-   -   All-in-one CarPC 1.5GHz (https://www.acuraforums.com/forum/audio-visual-electronics-25/all-ne-carpc-1-5ghz-2766/)
TIPTL08 Sep 5, 2008 04:12 PM
Double DIN CarPC that just came out:
The specifications/features from the website:
»</font></font> High-Brightness, Low-Glare 7" Digital LCD Panel</font></font>
»</font></font> Independent AM/FM Radio</font></font>
»</font></font> SANYO 10 Disc Changer Compatible (Independent Play)</font></font>
»</font></font> Upgraded 1.5GHz Pentium CPU</font></font>
»</font></font> 1GB DDR333 Memory</font></font>
»</font></font> 120GB Hard Drive</font></font>
»</font></font> WiFi and Bluetooth Connectivity</font></font>
»</font></font> DVD-Reader and CD-Burner Combo Drive</font></font>
» </font>5-Wire </font></font></font></font>USB Resistive Touchscreen </font></font>
» </font></font>Touch Sensitive On-Screen Menu</font></font>
» </font></font>Rear-View Camera Support</font></font>
» Windows XP/Vista and Linux Compatible</font></font></font></font></font>
Features: </font><ul>[*]7" Low-Glare High Resolution INNOLUX TFT Digital Panel</font>[*]Up/Down Motorized Angle Adjustment </font></font>[*]Resolution: 800 x 480 </font>[*]Brightness: 400cd/m2</font>[*]Contrast: 450</font>:</font></font>1 </font>[*]Viewing Angle: Left/Right 160 degrees</font>[*]Touch Screen Display, Easy to Operate User Interface</font>[*]Intel Pentium 1.5GHz CPU (Upgradeable to 2.0GHz) </font></font></font>[*]1GB DD333 Memory</font>[*]120GB Hard Drive</font>[*]DVD-Reader and CD-Burner Combo Built-in</font>[*]6/12 Disc (CD or DVD) Changer Compatible</font>[*]Play CD/DVD Discs via Changer Without PC Boot-Up </font></font>[*]2x USB 2.0 Ports (Add USB Hub to Expand)
</font>[*]1x VGA Output (Support for Dual Display)</font>[*]Operating Temperature of -10C to 70C</font>[*]Power Consumption Less Than 27Watts</font>[*]Input of 7 to 20 Volts (Wide-Range)</font>[*]Supported Operating Systems: Windows XP/Vista, Linux, Win CE</font></font></font></font></font></font>[*]Anti-vibration and Electronic Shock Protection</font></font>[*]Excellent Heat Dissipation (Low-Thermal Design)</font></font>[*]WiFi 802.11G Internet/Network Access
</font></font>[*]Bluetooth Connectivity
</font></font>[*]Built-In GPS SiRF Star III Receiver (36 Channels)</font></font></font>[*]Built-in Four Channel Amplifier (4 x 50W Max. Output)</font>[*]Built-in Intelligent Automotive Power Supply</font>[*]Built-in Independent AM/FM Tuner with EQ Options</font></font>[/list]http://www.revo-sys.com/prodimages/D..._X300_01_M.jpg</font>
