-   Audio/Visual Electronics (https://www.acuraforums.com/forum/audio-visual-electronics-25/)
-   -   2000 Acura TL Factory Radio Question.... (https://www.acuraforums.com/forum/audio-visual-electronics-25/2000-acura-tl-factory-radio-questin-1146/)
nightpoison May 9, 2007 07:38 AM
I am hoping someone has the answer to this for me.
I have a 2000 Acura TL, with the factory install Bose Radio. Does the Radio have Audio out jacks on the back, so that I can install a sub in the trunk?
Thanks for your help.
AgigohmTL May 29, 2007 06:15 PM
No the factory TL bose radio does not have preouts, also the factory acura is also amped so you can't just replace the headunit. You need to rewire pretty much every speaker or connect directly bypassing the amps. What i am planning to do is just adding an amp and sub and connecting the the factory sub to the high level input on my amp. This should do the trick.
