-   AF Help & Suggestion Center (https://www.acuraforums.com/forum/af-help-suggestion-center-12/)
-   -   pressure settings on 2008 mdx clutch switches (https://www.acuraforums.com/forum/af-help-suggestion-center-12/pressure-settings-2008-mdx-clutch-switches-8167/)
split63 Oct 17, 2022 10:19 AM
does any on know what the pressure settings for on and off for a 2008 acura mdx transmission clutch engagement are replaced the 3rd and 4th switch and I still get a 842 code I tested the old ones and one switch activates at 36 lbs and the other is at 26 lbs the mdx will shift fine until it needs to go into 4th but only stays in 3rd thanks for any input I was going to change the filter but its a internal and the transmission would need to be remove also I did use 28610-rke-004 for 3rd and 28600-rke-004 for 4th
