pressure settings on 2008 mdx clutch switches
Old Oct 17, 2022 | 10:19 AM
split63's Avatar
Default pressure settings on 2008 mdx clutch switches
does any on know what the pressure settings for on and off for a 2008 acura mdx transmission clutch engagement are replaced the 3rd and 4th switch and I still get a 842 code I tested the old ones and one switch activates at 36 lbs and the other is at 26 lbs the mdx will shift fine until it needs to go into 4th but only stays in 3rd thanks for any input I was going to change the filter but its a internal and the transmission would need to be remove also I did use 28610-rke-004 for 3rd and 28600-rke-004 for 4th
Sir_LR
Sep 9, 2022 08:55 AM
krypton4
Sep 7, 2009 04:48 AM
rome237
Dec 17, 2008 10:12 AM
davidbeau
Apr 19, 2008 02:29 AM
