<TABLE cellSpacing=0 cellPadding=0 width="100%">
<T> <TR> <TD>Hi, I'm hoping someone can help me. </TD></TR> <TR> <TD colSpan=2></TD></TR> <TR> <TD colSpan=2>My car has been over-heating and I can not find the cause. I have had a new radiator put in as well as new sensors. I have also had a new thermostat put in, but the car still over-heats. The steam is coming from the back, near the firewall....Is it possible that my water pump needs to be replaced?</TD></TR></T></TABLE> |
water pump no doubt about it.Edited by: dan3lo |
if you see steam at the rear at the firewall , i would be surprises if it is the water pump.,, most likely a hose leaking .. You need to pressure test the cooling system to properly locate the cause also have you checked the coolant level ?? OOOps did not realize till now how old this post was ... Edited by: deserthonda |
I wonder if she even remembers that she ever posted a question here in the forums Desert! How you doin gumba? WheelBrokerAng [img]uploads/WheelBrokerAng/6C17F_tribe0409xcrowCleavIndians.jpg[/img] |
