-   AF Help & Suggestion Center (https://www.acuraforums.com/forum/af-help-suggestion-center-12/)
-   -   Drive shaft replacement (https://www.acuraforums.com/forum/af-help-suggestion-center-12/drive-shaft-replacement-1906/)
solarrover Dec 18, 2007 09:03 PM
Help
Trying to replace Right and left Drive shafts 1991 Legend and the left front shaft will not pull/pry out. Is ther any tricks to this process.
HELP
acuralegend Dec 21, 2007 06:59 AM
there is a snap ring on the inside of the shaft that gives it a bit of a lock in effect.
push the axles back in turn the shaft 1/4 turn and give it a gentle pry
do this many times and that ring should recenter and pop the axle out.
if you have been prying VERY hard against the housing and axle already you may have damaged that ring. if so be ready for 1 hell of a work out.
the last time i did this it took 2 hours per axle and a 4 foot prybar. i also started the engine and put the transmission in low and as it spun i pryed against it (this can damage the case and/or the transmission)
but what choice do you have.
i hope you can do it with the 1/4 turn trick.
bombs May 10, 2008 03:40 AM
Great advice acuralegend, maybe someday I could advice also to our other community, that’s www.spam.org .</span>Edited by: bombs
RICHARDON Aug 16, 2012 11:22 PM
Driving shaft is the vital part of vehicle. also known as 'propeller shaft' ;it is responsible for torque transmission.
