Drive shaft replacement
Old Dec 18, 2007 | 09:03 PM
solarrover's Avatar
Help
Trying to replace Right and left Drive shafts 1991 Legend and the left front shaft will not pull/pry out. Is ther any tricks to this process.
HELP
Old Dec 21, 2007 | 06:59 AM
there is a snap ring on the inside of the shaft that gives it a bit of a lock in effect.
push the axles back in turn the shaft 1/4 turn and give it a gentle pry
do this many times and that ring should recenter and pop the axle out.
if you have been prying VERY hard against the housing and axle already you may have damaged that ring. if so be ready for 1 hell of a work out.
the last time i did this it took 2 hours per axle and a 4 foot prybar. i also started the engine and put the transmission in low and as it spun i pryed against it (this can damage the case and/or the transmission)
but what choice do you have.
i hope you can do it with the 1/4 turn trick.
Old May 10, 2008 | 03:40 AM
bombs's Avatar
Great advice acuralegend, maybe someday I could advice also to our other community, that’s www.spam.org .</span>Edited by: bombs
Old Aug 16, 2012 | 11:22 PM
RICHARDON's Avatar
Driving shaft is the vital part of vehicle. also known as 'propeller shaft' ;it is responsible for torque transmission.
Lionbox
Nov 14, 2009 01:36 PM
bospet40
Nov 29, 2008 05:12 AM
multiara
Oct 24, 2007 01:35 PM
moschos23
Mar 15, 2007 06:50 PM
mikect22
Jul 22, 2006 12:08 PM
