Reguarding the break light lamp lit on the dash board...is this a break issue or a lamp issue????Edited by: mreed
lol..it could be either...are ur other brake lights working??
its not break issue problem will be in lamp or in wiring
Try to check the fuse of the break light and change it. Also try to change break light bulb. If it's still not working check your wiring..:)
| All times are GMT -5. The time now is 05:56 AM. |
