<DIV id=post_message_1254221>I recently purchased a 1990 Legend LS (first time Acura owner)I ripped out all the carpet and seats and when I was reinstalling the new carpet I had to disconnect the Alarm box under the drivers seat and now it will not start.I did not receive a remote with the car only a single key.All the dash lights light up and all accessories work but when you turn the key all the way to turn the engine ---nothing ,I hear the what I believe is the starter relay to click on passenger side floor board above foot level to click.The ECU only flashes once just for a second when you turn on the key. I have also pulled the fuse under the hood to reset the ECU.I found some info on alldatapro.com but I cannot find wiring diagrams to either bypass the alarm or better yet to reset the alarm.</DIV>
Originally Posted by 1990legendLS
<div id="post_message_1254221">I recently purchased a 1990 Legend LS (first time Acura owner)I ripped out all the carpet and seats and when I was reinstalling the new carpet I had to disconnect the Alarm box under the drivers seat and now it will not start.I did not receive a remote with the car only a single key.All the dash lights light up and all accessories work but when you turn the key all the way to turn the engine ---nothing ,I hear the what I believe is the starter relay to click on passenger side floor board above foot level to click.The ECU only flashes once just for a second when you turn on the key. I have also pulled the fuse under the hood to reset the ECU.I found some info on alldatapro.com but I cannot find wiring diagrams to either bypass the alarm or better yet to reset the alarm.</div>
does it crankover???
but no vroom??? |
We have same problem so I drop mine to shop then the mechanic told me that the problem is my Acura Vigor Alternator, do I need to purchase a new one?</span> Edited by: bombs |
can you put the alarm box back in it and see if it runs and starts?
