-   AF Help & Suggestion Center (https://www.acuraforums.com/forum/af-help-suggestion-center-12/)
-   -   2008 mdx will not shift into 4th gear (https://www.acuraforums.com/forum/af-help-suggestion-center-12/2008-mdx-will-not-shift-into-4th-gear-8173/)
split63 Oct 20, 2022 11:26 AM
replaced 4th gear clutch pressure switch still doesn't go into 4 all gears shift fine replaced the switch with a new one and checked the old one by bench testing and it worked fine so thats not the problem i was wondering if it could be the pressure control solenoid a,b,or c
