Vigor The Mid-Sized FF Sedan.
How To Replace the Power Steering Pump on a '94 Vigor
Old 08-19-2011, 01:29 PM
jdtechtalk00's Avatar
Default How To Replace the Power Steering Pump on a '94 Vigor
Hello folks,
If you are experiencing power steering that seems to go out for a second during slow turns, stiff steering in cold weather or while turning at low speeds, or a a squealing sound while turning, particularly at tight corners or while driving slowly, then your power steering pump may be on its way out. Don't wait for it to take a dive on you though- be proactive and replace the power steering pump on your Vigor before catastrophe strikes!
--Reference Material--
1994 Acura Vigor Power Steering Pump diagram
1) Place a suitable drain pan under the vehicle, then disconnect the power steering hoses from the pump to drain the fluid.
2) Remove the belt by loosening the pump adjusting bolts and mounting bolts.
3) On the 3.5RL, Legend or Vigor, remove the air cleaner cover and air intake duct.
4) Cover the alternator (Integra, 2.2CL & 2.3CL) or the crankshaft pulley (3.0CL & 3.2TL) with some rags to protect it from any spilled power steering fluid.
5) Disconnect and plug the inlet and outlet hoses from the pump.
6) Unfasten the pump mounting bolt(s), then remove the pump from the vehicle.
WARNING: Do not turn the steering wheel with the pump removed.
7) Cover the opening of the pump with a piece of tape to prevent any foreign material from entering the pump.
8) If you are replacing the pump and need to transfer the pulley, hold the steering pump in a suitable soft-jawed vise, hold the pulley with a suitable universal pulley holding tool, then remove the pulley nut and pulley.
9) Installation is the reverse of the removal procedure. Bleed the power steering system.
Old 10-29-2011, 11:17 AM
cool thanks for that info
Old 11-05-2011, 12:07 PM
Thumbs up Hello There Member jdtechtalk00
Originally Posted by jdtechtalk00
Hello folks,
Thank You for this post..it was and is very good. Great information for our members..
Old 02-02-2012, 04:22 AM
that's really great and happy to see the post.
Old 11-23-2014, 11:41 PM
Default nice post
bradleyjay11
04-13-2013 01:57 PM
bungln
05-07-2012 12:29 PM
bee99001
07-12-2008 05:59 PM
ampeg11
12-09-2007 07:36 PM
DianeT161
10-02-2007 09:47 PM
Quick Reply: How To Replace the Power Steering Pump on a '94 Vigor
