Suspension Is your ride slammed to the ground? Did you lift it so high you need a ladder to get in? Step in and let's talk about it...
Strange Front Tire WEAR
Old 07-11-2009, 10:13 AM
Greg105's Avatar
Default Strange Front Tire WEAR
I have an 07 MDX with 40,000 miles. I just noticed both front tires are getting chewed up about 1 1/2 inches in from where the outside tread starts. Its on both sides of the tire and on both front tires. The tread in the middle between the two areas gettig chewed up is in great shape with another 10 to 15,000 miles of tread life left.
The car is going to the dealer Monday, but was wondering if anyone has an idea what is causing the problem. I want to be knowlegable when I go to the dealer on Monday if they say it is an alignment problem.
Old 07-11-2009, 01:42 PM
rsxsblue_1's Avatar
0tires are supposed to wear in the dead center in and out. The mdx is an all wheel drive vehicle. The camber could be off or it could need an alignment. tell them to check your toe in.
Old 07-22-2009, 09:16 AM
jws1112's Avatar
I have a 2003 Acura TL-S with a similar problem - both front tires with 30K miles or so are wearing on the outside edge (both inside and outside). Greg105, did the dealer find anything for your MDX?
Old 08-01-2009, 02:08 PM
Question Hi Members
Are either of you members rotating your tires every so often like three to 6 times a year.
I rotate mine evey other oil change. about 6,000 miles
Old 08-04-2009, 02:06 PM
boosted475's Avatar
and making sure your tires are inflated properly make a huge difference.
In tread wear and gas mileage!
Old 08-05-2009, 03:43 PM
Smile
Boosted 475 has got that right..why do you think they put
those TPMS's on all the new cars tires?
Is there any one that didn't know about TPMS?
Old 08-05-2009, 04:12 PM
boosted475's Avatar
yup I checked my tpms at least once each time I got in the car
Old 10-06-2009, 12:10 PM
Lightbulb Hello Member
Is that right, would you mind telling us all how you do that?
Old 10-07-2009, 01:19 PM
boosted475's Avatar
Ummm.. I push the info button on my RL's steering wheel until I see my tire pressures show up on my display???
Bogey155
09-16-2009 04:37 PM
isimplyexist
02-15-2008 03:30 PM
rsrhcp
12-05-2007 11:06 PM
Andy PL
11-04-2007 01:49 PM
gonzo9091
01-23-2007 09:13 PM
Quick Reply: Strange Front Tire WEAR
