Suspension Is your ride slammed to the ground? Did you lift it so high you need a ladder to get in? Step in and let's talk about it...
Need some help
Old 09-16-2009, 03:54 AM
gslife08's Avatar
Question Need some help
I recently purchased a 88 integra and was curious if anyone could point me in the right direction to where i could find some decent suspension components or what to do.. Just wish it had shock/strut assembly on all four corners. idk can anyone help.
Old 09-17-2009, 04:51 PM
Wink Hello New Member
I moved you down to this forum where you can get help..Please make sure you post in the correct forums .
Thank You!
Old 10-08-2009, 07:50 PM
Lightbulb Hello Member
I have yet to see a lowering system for that old of Integra...
Let me know if you ever find any...
Old 10-09-2009, 03:22 AM
gslife08's Avatar
Question hhmmmm
is there any way of swapping from a newer integra or a different honda that has a coil spring/shock combo.???
Old 10-09-2009, 03:29 AM
gslife08's Avatar
found a site that has ground control coilover kit for older acura. here is the site
http://www.eautoworks.com/product-Gr...ntrol-4451.htm
Old 10-09-2009, 01:32 PM
MAXDC5's Avatar
I would suggest OEM to reduce any more wear to your vehicle. Because it is an Older car using the part specifically made for it would increase the life span.
http://acurapartswarehouse.com
these guys have pretty good prices on parts and cool features that let you save your car so next time you visit the site your car is already there.
Old 10-27-2009, 09:36 AM
lovecar's Avatar
Hi
Why dont u try www.autopartsway.ca .Its really cool and the prices are really cheap.
Old 11-20-2009, 04:08 AM
marryfoxgirl's Avatar
Default Need some help
Before I installed joomla, I installed other CMS via cpanel-fantastisco. The installation is very easy, but I dont like that CMS so I decided to installed joomla via cpanel also. But this time I am getting error saying I already installed joomla and cant create the database. I cant I installed the previous CMS via cpanel because I think some files are missing. Please help. Thanks
_______________________________________
Website I developed for cash advances Toronto company.
  #9
Old 12-13-2009, 08:47 AM
annothe09's Avatar
You will introduce some bump steer. It all depends on what you do with the suspension. Lowering the control arm mounting points may help. Move it temproary and run the suspension thru its range and see what you get.
  #10
Old 12-28-2009, 07:39 AM
Plobbig09's Avatar
im actually going to get some Ksport Kontrol coilovers thats why im asking. but thanks man. oh and try and get ranchos next time the monroes are good but ranchos are better
Quick Reply: Need some help
