Wheels and Tires Rims and treads
change to summer tires and wheels
Old 03-29-2012, 09:38 PM
actx601's Avatar
Default change to summer tires and wheels
Hi,
I am just wondering how to change tires with wheels on these Acura cars. I used to have VW cars and all I do is loose the four nuts that holds the wheel then pull the wheel out install the new wheel(with tire) and screw back the four nuts and that's it. On the Acura it looks the big center nut needs to be
unscrewed. But I see there's a nip on it. Do I pry open the nip to unscrew it ?
It seems to me this will be a weak spot the next time I mount the new wheel.
Any idea ?
Peter
Old 04-13-2012, 12:36 PM
NC_Tech007's Avatar
No, you don't need to touch that. It's as simple as removing the 5 lug nuts (yay upgraded from 4!). Make sure you re-torque them to 80 ft-lbs.
dreamcar88
08-21-2009 10:37 AM
ranga227
07-08-2009 09:30 AM
Jaylyons1
06-21-2008 12:19 AM
stumpy013
05-10-2008 09:15 PM
JoeBlowRacing
03-14-2007 02:22 AM
Quick Reply: change to summer tires and wheels
